方案下载应用领域 | 石油/化工 |
检测样本 | 基础有机原料 |
检测项目 | |
参考标准 | - |
Isopropyl alcoho l (IPA) is one of the most commonly used organic solvents in the semiconductor industry. Silicon wafers are dried after surface cleaning in the manufacturing process and IPA is frequently used during the drying step. The purity of IPA used is critical since these materials come in direct contact with the silicon wafers and any contaminants present at this stage could be detrimental to the overall performance of the final product. Plasma - based instrument ation is widely used in the semiconductor industry due to its multielement capability and sensitivity compared to techniques such as Flame Atomic Absorption Spectroscopy (FAAS). However a robust plasma is required for the analysis of organic matrices. M icrowave Plasma Atomic Emission Spectroscopy (MP - AES) uses magnetically - coupled microwave energy to generate a stable plasma that is highly suited to the analysis of organic solvents. The Agilent 4200 MP - AES features an advanced microwave cavity and a torch designed to handle a wide range of samples, with better detection limits and an increased working range, compared to FAAS. Major elements (Ca, K, Na and Mg) in IPA can be easily determined using MP - AES with little sample preparation.
使用 Agilent InfinityLab 在线液相色谱 系统实现对流动化学反应器中反应过 程的实时监测
使用配备氦气节省模块以进行载气 切换的 Agilent 8850 气相色谱系统 分析香草提取物的方法转换
应用 QuEChERS 方法结合 Agilent 7000 系列三重四极杆气质联用仪测定甜菜中 的多农药残留
CrossLab企业资产管理服务
Agilent 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
