方案下载应用领域 | 地矿 |
检测样本 | 其他 |
检测项目 | |
参考标准 | - |
The analytical requirements of the geological survey and mining industries are demanding in terms of high number of samples, number of elements, time/cost constraints and the difficult matrices. Depending on the range of elements and concentrations, some samples are analyzed twice, with higher concentration elements measured by ICP-OES (ICP-optical emission spectroscopy), and trace elements measured using ICP-MS. For such samples, a single analysis would improve productivity and lower cost per sample. While ICP-MS is the only technique capable of measuring all of the required elements at trace levels, the wide range of analyte concentrations, high acid concentration and high total dissolved solids (TDS) of rock digests are challenging for the technique.
应用 QuEChERS 方法结合 Agilent 7000 系列三重四极杆气质联用仪测定甜菜中 的多农药残留
使用 Agilent BioTek Synergy Neo2 Hybrid 多功能微孔板检测仪测定脂质纳米颗粒表观 pKa
使用 ICP-OES 结合自动稀释测定锂盐中的多种元素
CrossLab企业资产管理服务
Agilent 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
