方案下载应用领域 | 生物产业 |
检测样本 | 生物能源 |
检测项目 | |
参考标准 | - |
Inductively Coupled Plasma Mass Spectrometry (ICP-MS) is used increasingly in metallomic studies to analyze metals and metal species and their interactions within biological and ecological systems. It is an elemental detection technique that uses a very high temperature argon plasma as the ion source. As a result, a given concentration of an element provides a signal that is broadly consistent, irrespective of the compound structure or sample matrix. Key to achieving accurate and reliable measurements is the ability to reduce and eliminate polyatomic interferences that otherwise would bias the analytical results. Recent development of a triple quadrupole ICP-MS (ICP-QQQ) dramatically improves the efficiency and reliability of removal of spectral interferences, making it easier to analyze elements with spectral overlaps such as iron, sulfur and selenium. Furthermore, the more effective removal of spectral overlaps allows access to multiple isotopes of many elements, enabling quantification of metalloproteins and peptides through the use of isotope dilution mass spectrometry (IDMS) analysis, which eliminates the requirement for compound specific calibration standards [1]. This absolute quantification technique allows accurate
使用 Agilent InfinityLab 在线液相色谱 系统实现对流动化学反应器中反应过 程的实时监测
使用配备氦气节省模块以进行载气 切换的 Agilent 8850 气相色谱系统 分析香草提取物的方法转换
应用 QuEChERS 方法结合 Agilent 7000 系列三重四极杆气质联用仪测定甜菜中 的多农药残留
CrossLab企业资产管理服务
Agilent 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
