方案下载应用领域 | 食品/农产品 |
检测样本 | 其他食品 |
检测项目 | 过敏原>其他 |
参考标准 | - |
The Agilent 1290 Infi nity II LC was used to analyze additives such as sweeteners, preservatives, and caffeine in various food products, beverages, and consumer toothpaste. The developed method facilitates accurate and sensitive determination of nine additives using a diode array detector (DAD) and an evaporative light scattering detector (ELSD) placed in series. After the DAD, a valve was installed to remove nonretained solutes in reversed-phase LC, which could increase the noise level of the ELSD. Total analysis time, including re-equilibration, was below 10 minutes with minimal sample preparation. Method performance was evaluated with standard solutions as well as with a series of real samples.
使用 Agilent InfinityLab 在线液相色谱 系统实现对流动化学反应器中反应过 程的实时监测
使用配备氦气节省模块以进行载气 切换的 Agilent 8850 气相色谱系统 分析香草提取物的方法转换
应用 QuEChERS 方法结合 Agilent 7000 系列三重四极杆气质联用仪测定甜菜中 的多农药残留
CrossLab企业资产管理服务
Agilent 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
