方案下载应用领域 | 石油/化工 |
检测样本 | 胶黏剂助剂 |
检测项目 | |
参考标准 | - |
Lignins impart rigidity to woody plants, achieved by cross-linking different plant polysaccharides that strengthen the cell walls, and are the second most abundant organic polymers on earth. The name itself is derived from the Latin word lignum, meaning wood. Lignins are important in the papermaking process – it is lignin in the pulps used to make newspapers which causes them to yellow with age and it must be removed to produce high quality bleached paper. The base monomers are phenylpropanoids, aromatics with carboxylic acid and hydroxyl functionalities, which form highly complex, amorphous, three-dimensional polymers. It is also used as a raw material for several chemicals, often via lignosulfonates. Determining the molecular weight distribution and structural properties of lignins is an important step in understanding their behavior in wood pulps. However, the analysis is very challenging, as they are very difficult to extract from wood pulps and often degrade during this process. There is a huge variation in the structure of lignins, with the material showing great heterogeneity from one source to the next. The accurate molecular weight distributions of four samples of lignin were investigated by GPC with viscometry.
使用 Agilent 8697 顶空进样器和 8850 GC-FID 系统进行制药行业的残留溶剂分析
利用透射拉曼光谱对软凝胶胶囊进行定量与鉴定测试
检测婴儿配方奶粉、牛奶和鸡蛋中的 30 种全氟烷基和多氟烷基化合物
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
