方案下载应用领域 | 食品/农产品 |
检测样本 | 淀粉及淀粉制品 |
检测项目 | 理化分析>物理性指标 |
参考标准 | - |
Starches are composed of a mixture of the glucose polymers amylose and amylopectin in a ratio of about 30:70 depending on the source. Starches are primarily used as thickening agents in cooking and to provide strength in textiles and papermaking, however, the industrial applications of starches are ever increasing due to their strength, toughness and biodegradation properties. For these materials, the molecular weight distribution of the polymers determines many of their final properties and therefore the end-use suitability. Gel permeation chromatography (GPC) with Universal Calibration, employing a viscometer in combination with a differential refractive index detector, may be used to determine accurate molecular weights for biopolymers, such as starches, that are independent of the standards used in the column calibration. Two starches were analyzed using these techniques, as the thickening properties of the different samples were found to be subtly different.
单克隆抗体的高分离度、高通量体积 排阻色谱分析
采用液相色谱-四极杆串联飞行时间高分辨质谱分析锂电池中的碳酸酯有机溶剂组分
使用 Agilent 5800 ICP-OES 测定固态 电解质锂镧锆钽氧 (LLZTO) 中的 主量元素
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
