方案下载应用领域 | 石油/化工 |
检测样本 | 其他 |
检测项目 | |
参考标准 | - |
Polybutadiene is an elastomer – a polymer that exhibits elasticity. Elasticity is the ability to deform under external stress but return to the original form after removal of the stress. Polybutadiene is a synthetic rubber manufactured from the monomer 1,3-butadiene. Polybutadiene exhibits 80% recovery after stress, one of the highest values of a synthetic material. It is commonly used to coat electronic assemblies due to its extremely high electrical resistivity. Polybutadiene displays a high wear resistance, low heat build-up after repeated flexing and a low rolling resistance, making it suitable for applications such as tires. It is often used in combination with other materials to produce rubber blends with differing properties. The 390-MDS offers triple detection GPC by employing a light scattering detector and a viscometer in combination with a differential refractive index detector, to determine accurate molecular weights for polymers for which narrow standards are not available, such as polybutadiene.
使用 Agilent 8697 顶空进样器和 8850 GC-FID 系统进行制药行业的残留溶剂分析
利用透射拉曼光谱对软凝胶胶囊进行定量与鉴定测试
检测婴儿配方奶粉、牛奶和鸡蛋中的 30 种全氟烷基和多氟烷基化合物
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
