方案下载应用领域 | 医疗/卫生 |
检测样本 | 其他 |
检测项目 | |
参考标准 | - |
“Smart materials” are capable of varying their physical properties in response to environmental changes or stimuli. Such stimuli include temperature, pH, solvent composition, and electric field strength. In particular, smart hydrogels, which change their shrinking and swelling characteristics in response to external stimuli, have been studied for use in engineering and biomedical applications, such as controlled drug release. Poly(n-isopropylacrylamide) (PNIPAM) gel is an important smart hydrogel that responds to temperature changes. PNIPAM gels exhibit negative thermosensitivity, meaning that they undergo a significant level of shrinkage with increasing temperature. Precise control over a hydrogel’s shrinking and swelling characteristics is desirable since this may lead to control over its drug release/ uptake properties. Among other important properties that affect the thermosensitivity of PNIPAM, such as particle structure and size, a key characteristic is the molecular weight distribution. The molecular weight distributions of two PNIPAM polymers were accurately measured by means of GPC with online viscometry, allowing application of the universal calibration technique. This method permits an accurate calibration of the GPC system based upon molecular size in solution (using the relationship between the viscosity of the eluting polymer and its molecular weight). This in turn allows accurate molecular weights to be calculated even though the polymer standards used are not chemically identical to the polymer under investigation, as the column is separating on size not molecular weight. As a result, the molecular weight data usually obtained via this technique are very accurate, in contrast to conventional GPC employing a concentration detector only (eg UV, RI), which provides molecular weight data relative to the polymer calibration standards used. The 390-MDS can be used to provide accurate molecular weights for polymers of unusual structure by employing differen
使用 Agilent InfinityLab 在线液相色谱 系统实现对流动化学反应器中反应过 程的实时监测
使用配备氦气节省模块以进行载气 切换的 Agilent 8850 气相色谱系统 分析香草提取物的方法转换
应用 QuEChERS 方法结合 Agilent 7000 系列三重四极杆气质联用仪测定甜菜中 的多农药残留
CrossLab企业资产管理服务
Agilent 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
