方案下载应用领域 | 食品/农产品 |
检测样本 | 其他食品 |
检测项目 | 过敏原>其他 |
参考标准 | - |
There are many advantages in miniaturizing sample preparation. The use of less solvent reduces solvent cost and waste. Smaller sample sizes are easier to handle, store, and process in the lab. Reduction in sample amount provides cost savings on sample preparation sorbent and substantial decreases in cost associated with the use of labeled compounds as internal standards. With a smaller sample size, it may be possible to use additional labeled compounds for troublesome analytes that are cost prohibitive with larger sample sizes. We analyzed pesticides in food using miniaturized QuEChERS extraction and thultra-efficient ionization source of the Agilent 7010 Triple Quadrupole GC/MS, which reduces injected sample volume by 75%. On average, limits of quantitation (LOQ) ~10 ng/g were reached for 95% of the 126 pesticides studied in apple, carrot, and broccoli. Less matrix injected delivers prolonged uptime and sustained performance and, therefore, lower maintenance costs. By injecting only 25% of the standard 2 μL injection volume and implementing our recommended pesticide analysis method, we analyzed the pesticides at or below threshold MRLs of the EPA, EU, and Japan, 0.01 mg/kg (10 ng/g), which was adequate to monitor exposure.
使用 Agilent InfinityLab 在线液相色谱 系统实现对流动化学反应器中反应过 程的实时监测
使用配备氦气节省模块以进行载气 切换的 Agilent 8850 气相色谱系统 分析香草提取物的方法转换
应用 QuEChERS 方法结合 Agilent 7000 系列三重四极杆气质联用仪测定甜菜中 的多农药残留
CrossLab企业资产管理服务
Agilent 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
