方案下载应用领域 | 石油/化工 |
检测样本 | 其他 |
检测项目 | |
参考标准 | - |
The structure of many common types of polymer may be modified by either postpolymerization reaction or by the use of modified monomers, producing materials with new and novel properties. Understanding and assessing the effect of these modified structures on the behavior of polymers in various applications is crucial to developing novel uses for such materials. Polystyrene is one of the most commonly seen polymers, used primarily for the manufacture of packing materials. Modified forms of polystyrene may be produced by the use of novel styrene monomers. Gel permeation chromatography (GPC) is a well-known technique for assessing the molecular weight distribution of polymers, a property that influences many physical characteristics. Importantly, increasing the sophistication of the GPC experiment by the use of additional detectors allows the structure and solution properties of polymers to be assessed, of interest when studying the affect of structural modifications on a polymer. Triple detection employing a light scattering detector and a viscometer in combination with a refractive index detector may be used to determine accurate molecular weights for polymers for which narrow standards are not available, and to assess their solvation properties. This application note describes the analysis of a sample of polystyrene and a modified polybromostyrene material by triple detection.
使用 Agilent 8890 气相色谱和 TCD/FID 系统分析氢气中的氦气、 氩气、氮气和烃类杂质
使用 Agilent InfinityLab 在线液相色谱 系统实现对流动化学反应器中反应过 程的实时监测
使用配备氦气节省模块以进行载气 切换的 Agilent 8850 气相色谱系统 分析香草提取物的方法转换
CrossLab企业资产管理服务
Agilent 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
