方案下载应用领域 | 石油/化工 |
检测样本 | 环氧树脂 |
检测项目 | |
参考标准 | - |
Epoxy resins are complex materials manufactured by the reaction of a ‘resin’ with a ‘hardener’. This produces a cross-linked polymer that is extremely strong, tough and may be used to bond materials together. The resin component of the mixture is an epoxide pre-polymer, typically produced by the reaction of an epoxide with bisphenol-A. The resulting short-chain material contains pendant –OH and epoxide functionalities and is polar in nature. The molecular weight of the epoxide chains in the resin is important as this influences the curing rate of the final epoxy resin formulation when mixed with the hardener, however, accurate molecular weights are difficult to obtain due to the complex, inhomogeneous nature of the epoxide polymer chains. Gel permeation chromatography (GPC) is a well-known technique for assessing the molecular weight distribution of polymers, a property that influences many physical characteristics such as the curing time of epoxy resins. GPC viscometry employing a viscometer in combination with a differential refractive index detector has the advantage of allowing the determination of accurate molecular weights for structurally complex polymers and co-polymers via the Universal Calibration approach. Using this methodology, the same molecular weights are determined for samples regardless of the standards used to create the calibration. This application note describes the analysis of two samples of epoxide pre-polymers by GPC viscometry
单克隆抗体的高分离度、高通量体积 排阻色谱分析
采用液相色谱-四极杆串联飞行时间高分辨质谱分析锂电池中的碳酸酯有机溶剂组分
使用 Agilent 5800 ICP-OES 测定固态 电解质锂镧锆钽氧 (LLZTO) 中的 主量元素
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
