方案下载应用领域 | 石油/化工 |
检测样本 | 糖类 |
检测项目 | |
参考标准 | - |
Polysaccharides are complex polymers constructed from sugar units. There is a wide range of polysaccharides, many of which show large structural differences due to the manner in which they are synthesized. This is most commonly seen in the presence of branches on the polymer chains of some polysaccharides, which strongly influences properties such as solution viscosity. Pullulan polysaccharide is composed of maltotriose units in the polymer backbone, produced from starch by the action of a fungus. Pullulan has a linear structure, whereas in contrast dextran is a complex glucan with many differing components manufactured from sucrose by bacterial action that has a highly branched structure. Investigating the structure of polysaccharides is of interest for determining their properties in applications such as their use as food additives. Gel permeation chromatography (GPC) is a well-known technique for assessing the molecular weight distribution of polymers, a property that influences many of the physical characteristics of these materials. GPC viscometry, employing a viscometer in combination with a differential refractive index detector, has the advantage of allowing the accurate determination of molecular weights for structurally complex polymers and co-polymers regardless of the their structure, via the Universal Calibration approach. GPC viscometry also reveals information about the solution viscosity of polymers, a property related to molecular size. Using this information, the branched structure of polymers can be investigated. This application note describes the analysis of two samples of polysaccharide by GPC viscometry, pullulan with a linear structure, and a highly branched dextran.
单克隆抗体的高分离度、高通量体积 排阻色谱分析
采用液相色谱-四极杆串联飞行时间高分辨质谱分析锂电池中的碳酸酯有机溶剂组分
使用 Agilent 5800 ICP-OES 测定固态 电解质锂镧锆钽氧 (LLZTO) 中的 主量元素
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
