方案下载应用领域 | 环保 |
检测样本 | 土壤 |
检测项目 | (类)金属及其化合物>银(Ag), 其它, 钙(Ca), 汞(Hg), 铁(Fe), 铜(Cu), 锌(Zn), 钠(Na), 铬(Cr), 镁(Mg), 钒(V), 钡(Ba), 铝(Al), 镉(Cd), 镍(Ni), 锑(Sb), 锰(Mn), 钾(K), 铅(Pb), 砷(As), 钼(Mo), 铍(Be), 硒(Se), 钴(Co), 铊(Tl) |
参考标准 | - |
Quadrupole ICP-MS (ICP-QMS) is one of the most widely used analytical techniques in inorganic testing laboratories, due to its performance characteristics of high sensitivity, low detection limits, wide dynamic range, and high speed multi-element analysis.
Recent advances have seen a dramatic improvement in matrix tolerance: Agilent’s High Matrix Introduction (HMI) technology uses aerosol dilution to reduce the sample matrix load on the plasma, ensuring that much higher matrix levels—up to % levels of total dissolved solids (TDS)—can be analyzed routinely.
Control of interferences has also been improved significantly, with Agilent’s octopole-based collision/reaction cell (CRC) operating in helium (He) collision mode to eliminate a wide range of matrix based polyatomic interferences using one set of cell conditions [1]. Reliable and accurate quantitation of all required elements at the regulated levels in a wide variety of sample matrices is now possible using ICP-QMS. However, some applications require greater sensitivity for some specific elements, while some complex sample matrices may cause spectral interferences that remain a challenge.
利用透射拉曼光谱对软凝胶胶囊进行定量与鉴定测试
检测婴儿配方奶粉、牛奶和鸡蛋中的 30 种全氟烷基和多氟烷基化合物
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
