方案下载应用领域 | 制药/生物制药 |
检测样本 | 复合材料 |
检测项目 | 溶出物 |
参考标准 | - |
Data were acquired on an Agilent 7200 GC/Q-TOF in both electron ionization (EI) and chemical ionization (CI) modes to ensure a comprehensive identification of the extracted compounds. El data have been acquired to identify compounds using the NIST library. Compound distribution across the different samples was visualized based on a chemometric approach using Agilent MassHunter Mass Profiler Professional software.
In this work, four drug containers originating from different manufacturers have been investigated, generating profiles for semivolatile extractable compounds. Data were acquired on an Agilent 7200 GC/Q-TOF in both electron ionization (EI) and chemical ionization (CI) modes to ensure a comprehensive identification of the extracted compounds. El data have been acquired to identify compounds using the NIST library. Compound distribution across the different samples was visualized based on a chemometric approach using Agilent MassHunter Mass Profiler Professional software. Compounds that could be only tentatively identified after EI were confirmed using parent ion mass data generated in CI mode. Approximately 170 compounds were identified in each container. The results indicate that the combination of EI and CI data increased the number of identified extractable compounds, enabling a thorough evaluation of container systems.
使用 Agilent InfinityLab 在线液相色谱 系统实现对流动化学反应器中反应过 程的实时监测
使用配备氦气节省模块以进行载气 切换的 Agilent 8850 气相色谱系统 分析香草提取物的方法转换
应用 QuEChERS 方法结合 Agilent 7000 系列三重四极杆气质联用仪测定甜菜中 的多农药残留
CrossLab企业资产管理服务
Agilent 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
