使用 Agilent 1290 Infinity II 二维液相色谱解决方案对茶进行全二维液相色谱分析(–)-Epigallocatechin gallate
2017/12/20   下载量: 2
方案下载
应用领域 食品/农产品
检测样本 茶叶
检测项目
参考标准 -
Tea is one of the most widely consumed beverages in the world, and is produced from the tea plant Camellia sinensis. Depending on the processing methods of the leaves of Camellia sinensis after harvesting, green, oolong, or black tea is obtained. This Application Note shows the comprehensive 2D-LC analysis of purine alkaloids and catechins in green and black tea using the Agilent 1290 Infi nity II 2D-LC solution. The precision of retention time and peak volume is determined, and the purine alkaloids caffeine and theobromine as well as the catechins catechin, epicatechin, and epigallocatechin gallate contained in green and black tea are quantified.
方案下载
配置单
上一篇 采用液相色谱-四极杆串联飞行时间高分辨质谱分析锂电池中的碳酸酯有机溶剂组分
下一篇 使用 Agilent 1290 Infinity II 二维液相色谱解决方案对茶进行全二维液相色谱分析(–)-Epicatechin
文献贡献者
相关方案
当前位置: 安捷伦 方案 使用 Agilent 1290 Infinity II 二维液相色谱解决方案对茶进行全二维液相色谱分析(–)-Epigallocatechin gallate
