姜中氨基甲酸酯及其代谢物的残留物测定Methiocarb-sulfone
2017/12/20   下载量: 4
方案下载
应用领域 食品/农产品
检测样本 其他调味品
检测项目
参考标准 -
This application note describes a method for the simultaneous determination of 26 carbamates and their metabolite residues in ginger by ultra-high performance liquid chromatography tandem mass spectrometry (UHPLC-MS/MS) based on the work published by He, et al . [1]. The ginger samples were initially extracted using acetonitrile, followed by cleanup using NH2 solid phase extraction (SPE) column. The samples were then enriched by nitrogen evaporation, redissolved in a mixture of acetonitrile:water (1:1, v:v), and analyzed by UHPLC-ESI-MS/MS. With matrix-matched standard calibration for quantitation, the method showed excellent linearity, with correlation coefficients of》=0.99 for all compounds in the examined concentration range. The limits of detection and limits of quantitation were in the ranges of 0.050–2.0 μg/kg and 0.20–5.0 μg/kg, respectively. At spiking levels of 10, 30, and 100 μg/kg, the recoveries for all compounds ranged from 70.9–119% with RSD of 1.0–11%. The method is simple, rapid, and sensitive, thus it can meet the requirements for the determination of carbamates and their metabolite residues in ginger.
方案下载
配置单
上一篇 采用液相色谱-四极杆串联飞行时间高分辨质谱分析锂电池中的碳酸酯有机溶剂组分
下一篇 姜中氨基甲酸酯及其代谢物的残留物测定Dimetilan
文献贡献者
相关方案
当前位置: 安捷伦 方案 姜中氨基甲酸酯及其代谢物的残留物测定Methiocarb-sulfone
