方案下载应用领域 | 食品/农产品 |
检测样本 | 其他调味品 |
检测项目 | |
参考标准 | - |
This application note describes a method for the simultaneous determination of 26 carbamates and their metabolite residues in ginger by ultra-high performance liquid chromatography tandem mass spectrometry (UHPLC-MS/MS) based on the work published by He, et al . [1]. The ginger samples were initially extracted using acetonitrile, followed by cleanup using NH2 solid phase extraction (SPE) column. The samples were then enriched by nitrogen evaporation, redissolved in a mixture of acetonitrile:water (1:1, v:v), and analyzed by UHPLC-ESI-MS/MS. With matrix-matched standard calibration for quantitation, the method showed excellent linearity, with correlation coefficients of》=0.99 for all compounds in the examined concentration range. The limits of detection and limits of quantitation were in the ranges of 0.050–2.0 μg/kg and 0.20–5.0 μg/kg, respectively. At spiking levels of 10, 30, and 100 μg/kg, the recoveries for all compounds ranged from 70.9–119% with RSD of 1.0–11%. The method is simple, rapid, and sensitive, thus it can meet the requirements for the determination of carbamates and their metabolite residues in ginger.
单克隆抗体的高分离度、高通量体积 排阻色谱分析
采用液相色谱-四极杆串联飞行时间高分辨质谱分析锂电池中的碳酸酯有机溶剂组分
使用 Agilent 5800 ICP-OES 测定固态 电解质锂镧锆钽氧 (LLZTO) 中的 主量元素
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
