方案下载应用领域 | 钢铁/金属 |
检测样本 | 粗钢 |
检测项目 | 含量分析>镍元素 |
参考标准 | - |
Steel manufacturers conduct quality control testing for a range of metals and trace elements to ensure the grade and performance of their final product. The Standardization Administration of China uses their GB/T 20125-2006 standard “Low-alloy steel – Determination of multi-element contents – Inductively coupled plasma atomic emission spectrometric method” to control the quality of manufactured steel products. Different grades of steel have different specifications for elemental content, with most steel and stainless steel grades required to have less than 0.05 % by weight of Sulfur and 0.04 % by weight of Phosphorus. With the Inductively Coupled Plasma Optical Emission Spectroscopy (ICP-OES) technique easily able to measure elements at this concentration within a sample, laboratories are looking beyond whether an instrument can ‘do the job’ to whether a specific instrument can improve their sample throughput, lower their costs, simplify sample preparation and instrument operation, and deliver reliable results throughout the analysis of a large batch of samples. 2 This application note demonstrates the performance and benefits of Agilent’s 5100 Vertical Dual View (VDV) ICP-OES instrument in the analysis of steel samples, using the GB/T 20125-2006 method. The instrument offers many advantages for this application, which involves the rapid analysis of a large number of challenging steel samples.
单克隆抗体的高分离度、高通量体积 排阻色谱分析
采用液相色谱-四极杆串联飞行时间高分辨质谱分析锂电池中的碳酸酯有机溶剂组分
使用 Agilent 5800 ICP-OES 测定固态 电解质锂镧锆钽氧 (LLZTO) 中的 主量元素
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
