方案下载应用领域 | 石油/化工 |
检测样本 | 汽油 |
检测项目 | 含量分析>钙 |
参考标准 | - |
Trace metals in gasoline are a major source of environmental pollution. They can also adversely affect the performance of automotive engines. Silicon (Si) contamination can be especially problematic as deposits damage components such as catalytic convertors and oxygen sensors leading to costly repairs. ICP-OES is often used for the determination of trace elements in petroleum products due to its reliability, robustness and sensitivity. A successful analysis needs to take account of sample characteristics, such as the high volatility of gasoline. Continuous loading of the plasma with gasoline can affect the stability of the signal and lead to carbon build up on the torch that may cause the plasma to extinguish. 2 In this study, the Agilent 5100 Synchronous Vertical Dual View (SVDV) ICP-OES was used for the analysis of 21 elements in gasoline, including Si. Oxygen was added to the auxiliary argon gas flow to reduce carbon build up on the torch, maintain a stable plasma and reduce carbon emission from the organic solvent. A programmable temperature spray chamber, set to -10 °C, was used to reduce vapor loading on the plasma, ensuring a more stable plasma.
使用 Agilent 8697 顶空进样器和 8850 GC-FID 系统进行制药行业的残留溶剂分析
利用透射拉曼光谱对软凝胶胶囊进行定量与鉴定测试
检测婴儿配方奶粉、牛奶和鸡蛋中的 30 种全氟烷基和多氟烷基化合物
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
