方案下载应用领域 | 地矿 |
检测样本 | 金属矿产 |
检测项目 | |
参考标准 | - |
Traditionally, geological samples are analyzed using flame atomic absorption (FAAS) and/or radial ICP-OES with a vertical torch. Achieving high sample throughput at a low cost per analysis for geochemical samples can be challenging when using these techniques. The samples often have a wide range of element concentrations, requiring multiple dilutions, particularly when using FAAS. The samples also have high levels of total dissolved solids (TDS), which requires frequent cleaning of the sample introduction system. In this application note, the Agilent 5100 Synchronous Vertical Dual View (SVDV) ICP-OES was used to analyze geochemical samples containing up to 2.5% TDS. As well as demonstrating the accuracy and flexibility of the instrument, the sample measurement rate and argon consumption per sample were determined.
单克隆抗体的高分离度、高通量体积 排阻色谱分析
采用液相色谱-四极杆串联飞行时间高分辨质谱分析锂电池中的碳酸酯有机溶剂组分
使用 Agilent 5800 ICP-OES 测定固态 电解质锂镧锆钽氧 (LLZTO) 中的 主量元素
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
