方案下载应用领域 | 食品/农产品 |
检测样本 | 蔬菜 |
检测项目 | 农药残留>氯氰菊酯, 溴氰菊酯 |
参考标准 | 暂无 |
The first commercially available exact mass pesticide library for GC/Q-TOF has been developed by using three GC methods that employ backflush. A screening workflow using this library and the unique All Ions tools enables the detection of pesticide levels as low as 10 ppb in complex matrices.
Due to the complexity and variety of food matrices, a constantly growing interest in food safety, and an increasing list of pesticides, residue analysis has become a more complex task that requires high selectivity, sensitivity, and a high throughput approach for data analysis. State-of-the-art pesticide screening requires the consideration of more than 1,000 pesticides and their metabolites. Of these, as many as 600 to 800 compounds are included in routine monitoring programs.
The increasing global emphasis on pesticide screening is reflected in the implementation of European Union (EU) guideline SANCO/12571/2013. The most recent revision specifies criteria for qualitative screening without the use of expensive standards for each pesticide in each batch of samples.
An accurate-mass approach in pesticide screening using quadrupole time-of-flight mass spectrometry (Q-TOF) offers more reliable pesticide identification, and allows for a virtually unlimited number of compounds to be screened simultaneously.
Gas chromatography (GC) coupled to a Q-TOF mass spectrometer provides an ideal analytical tool that can be used to screen, confirm, and quantify trace levels of both
target and unknown compounds, even in complex matrices. This application note describes the creation of a curated GC/Q-TOF exact mass electron ionization (EI) library of pesticides and the development of an accurate mass pesticide screening workflow designed to help improve reliability and increase throughput of pesticide residue analysis. More than 740 EI spectra of pesticides were generated using the
high-resolution Agilent 7890 GC, coupled to an Agilent 7200 Series GC/Q-TOF System.
Conclusions
The accurate mass power of the Agilent 7200 GC/Q-TOF System has enabled the development of the first commercially available exact mass pesticide library for GC/Q-TOF. A screening workflow using the unique All Ions tool has also been used successfully to screen for pesticide residues in five different food matrices.
单克隆抗体的高分离度、高通量体积 排阻色谱分析
采用液相色谱-四极杆串联飞行时间高分辨质谱分析锂电池中的碳酸酯有机溶剂组分
使用 Agilent 5800 ICP-OES 测定固态 电解质锂镧锆钽氧 (LLZTO) 中的 主量元素
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
