方案下载应用领域 | 制药/生物制药 |
检测样本 | 其他 |
检测项目 | 其他 |
参考标准 | 暂无 |
Peak-based fraction collection triggered by a UV signal threshold leads to satisfactory results in most cases. Some samples and applications, however, require special attention when fraction collection parameters are set. This Technical Overview describes different strategies on how to achieve best collection results using different settings on an Agilent 1260 Infinity II Preparative LC/MSD System. UV and mass-based fraction collection, fraction pooling, as well as recovery collection are discussed in detail to provide knowledge that can be turned into successful and confident fraction collection.
Abstract
Introduction
Agilent InfinityLab LC Purification Solutions1 mark a giant leap in efficient purification. The Agilent 1290 Infinity II Preparative Open-Bed Fraction Collector offers the highest flexibility regarding fraction collection modes and configuration of the fraction bed2 . The Agilent 1260 Infinity II Preparative LC/MSD System provides the base for successful fraction collection with a plus in usability.
In a compact housing, the Agilent 1260 Infinity II Preparative Binary Pump delivers high performance for preparative separations using columns from 9.4 up to 30 mm inside diameter. Samples are injected much faster with the Agilent 1260 Infinity II Preparative Autosampler, while carryover has been reduced significantly by a redesigned needle seat and integrated needle wash. With the Agilent extended portfolio of preparative fraction collectors, the system can be tailored to every need. For extra reliability, add an Agilent 1260 Infinity II Preparative Valve-Based Fraction Collector as a recovery collector, diverting the fraction collector waste outlet to distinct recovery positions.
To get the most out of the 1260 Infinity II Preparative LC/MSD System, fraction collection parameters need to be set properly. Although, in most cases, simple peak-based fraction collection triggered by the signal of an ultraviolet (UV) detector will produce satisfactory results, some scenarios might require special attention during method setup. This Technical Overview demonstrates different strategies on how to exploit the vast possibilities of the Agilent OpenLAB CDS ChemStation software to succeed with fraction collection even with challenging samples.
Conclusion
The Agilent 1260 Infinity II Preparative LC/MSD System excels in usability and focus on applications. The broad flexibility of the hardware is complemented by a large number of software features that provide the basis for successful fraction collection under variable conditions. If peak-based fraction collection triggered by a UV signal threshold is not enough to attack a challenging purification scenario, slope triggers, combined with MSD signals, fraction pooling, and recovery collection are only few of the possibilities a 1260 Infinity II Preparative LC/MS System has to offer
使用 Agilent InfinityLab 在线液相色谱 系统实现对流动化学反应器中反应过 程的实时监测
使用配备氦气节省模块以进行载气 切换的 Agilent 8850 气相色谱系统 分析香草提取物的方法转换
应用 QuEChERS 方法结合 Agilent 7000 系列三重四极杆气质联用仪测定甜菜中 的多农药残留
CrossLab企业资产管理服务
Agilent 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
