方案下载应用领域 | 制药/生物制药 |
检测样本 | 其他 |
检测项目 | 其他 |
参考标准 | 暂无 |
The Agilent 1290 Infinity II Preparative Open-Bed Fraction Collector sets new benchmarks in efficient and flexible fraction collection. The fraction bed can be equipped individually with six containers holding fraction tubes in eight different sizes. Three drawers provide easy access to collected fractions even during a run. Peak- and time-based fraction modes have been extended to eight combined modes, enabling the collection of volume or time slices, and including two recovery collection modes. Trigger combinations of ultraviolet (UV) with mass-selective detection (MSD) signals now include an AND/OR logic that gives extra flexibility for challenging purifications. This Technical Overview provides a deeper insight and typical application examples of the fraction modes, including collection results.
Abstract
Introduction
Fraction collection is the key feature that turns an analytical high-performance liquid chromatography (HPLC) system into a purification system. Simple as it may sound, fraction collection in general, and preparative-scale purification in particular, do have challenging facets. Flow rates in preparative-scale HPLC range from 5 up to 100 mL/min or above, generating fraction volumes of below 1 mL up to tens or even hundreds of mL. This demands collection vessels of different sizes, if the fraction collector capacity is to be used in an optimal way. Quick processing of collected fractions (re-analysis, pooling, and solvent evaporation) is desirable, creating the need for an easily accessible fraction bed.
The Agilent 1290 Infinity II Preparative Open-Bed Fraction Collector1 contains new and improved features that address all of these topics. Fraction containers holding tubes of different diameters (12, 16, 25, 30 mm) and lengths (100 or 150 mm) are optimized to hold fractions of 8 to 78 mL. The fraction bed can be equipped individually with six containers, and holds up to 432 single fractions, or a maximum fraction volume of 5,940 mL. Three drawers separate the fraction bed, and enable the exchange of full drawers even during operation. Only the currently active drawer is locked to prevent spills and sample loss.
Tubing kits with different inside diameters are available for optimized setup according to the flow rate used. As with the Agilent 1260 Infinity fraction collectors, the 1290 Infinity II Preparative Open-Bed Fraction Collector features a built-in delay sensor, enabling precise calibration of the delay between the detector and the fraction valve without any hardware modifications.
Along with hardware improvements, the 1290 Infinity II Preparative Open-Bed Fraction Collector offers several enhanced fraction collection modes that combine peak- with time-based collection, and include recovery collections. Fraction collection triggered by a combination of ultraviolet (UV) with mass-selective detection (MSD) signals has also been extended by a third mode, combining the advantages of logical AND/OR connections. This Technical Overview describes the different fraction collection modes available in the 1290 Infinity II Preparative Open-Bed Fraction Collector, and presents typical applications of the feature enhancements.
Conclusion
Besides a larger capacity, and a much more flexible configuration of the fraction bed, the Agilent 1290 Infinity II Preparative Open-Bed Fraction Collector offers new combined fraction modes that are tailored to the demands of different purification challenges. This Technical Overview provides application examples and collection outcomes of these fraction modes, including time-based collection combined with volume slices, peak-based collection combined with time slices, and two recovery collection modes. Peakbased fraction collection is demonstrated with a combination of ultraviolet (UV) and mass-selective detection (MSD) signals, connected by Boolean AND, as well as the novel AND/OR logic
使用 Agilent InfinityLab 在线液相色谱 系统实现对流动化学反应器中反应过 程的实时监测
使用配备氦气节省模块以进行载气 切换的 Agilent 8850 气相色谱系统 分析香草提取物的方法转换
应用 QuEChERS 方法结合 Agilent 7000 系列三重四极杆气质联用仪测定甜菜中 的多农药残留
CrossLab企业资产管理服务
Agilent 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
