方案下载应用领域 | 制药 |
检测样本 | 预防类生物药品 |
检测项目 | 含量测定>色谱法 |
参考标准 | / |
Comparing the Agilent 1290 Infinity II Bio LC System and Agilent 1290 Infinity II LC System for metabolomics
Metabolomics is a tool to decipher and understand the physiological state of a cell or organism. Recently, LC/MS emerged as the prevalent analytical technique of choice. However, there is still significant potential for improved robustness and ease of use. This application note demonstrates that a biocompatible flow path has significant advantages over stainless steel. These advantages were proven by comparing the Agilent 1290 Infinity II Bio LC and Agilent 1290 Infinity II LC. The 1290 Infinity II Bio LC showed improved peak shape and resolution for
phosphorylated compounds such as nucleotides and sugar phosphates without apparent adsorption effects, compared to the 1290 Infinity II LC. Excellent retention time RSD values of 0.1% were generated for intracellular metabolite extracts derived from Saccharomyces cerevisiae. These data suggest that essential metabolites for physiological parameters such as the adenylate energy charge could be analyzed consistently. Together, these results show that the 1290 Infinity II Bio LC is the perfect choice for a seamless and robust analysis in metabolomics.
使用 Agilent 5800 ICP-OES 测定固态 电解质锂镧锆钽氧 (LLZTO) 中的 主量元素
Agilent Vaya 手持式拉曼光谱仪的 不透明容器分析能力
使用 Agilent 8890 气相色谱和 TCD/FID 系统分析氢气中的氦气、 氩气、氮气和烃类杂质
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
