方案下载应用领域 | 制药/生物制药 |
检测样本 | 其他 |
检测项目 | 其他>方法开发 |
参考标准 | / |
The growing complexity of biopharma analysis calls for innovation that delivers excellence across the Beiopharmaceutical workflow. The Agilent InfinityLab Bio LC Solutions comprise a full range of entirely biocompatible and bio-inert LC systems that enables robust, accurate bioanalysis from drug discovery and development to QA/QC. By combining these systems with bio columns, MS detection, software, and services, we can help you create a complete solution to meet your biopharma challenges. This application compendium comprises a list of current applications demonstrating the high performance and versatility of the InfinityLab Bio LC Solutions for bioanalysis.
Charge variant analysis is a demanding application for applied liquid chromatography systems due to the use of highly corrosive buffer salts in combination with very shallow gradients for optimal separation. The evaluation of different salt gradients was performed on the Agilent 1290 Infinity II Bio LC System and analyzed for resolution as well as reproducibility.
The 1290 Infinity II Bio LC including High-Speed Pump, with its completely iron-free flow path, is optimally suited for the conditions used in biochromatography—avoiding potentially corrosive damage to the system. Excellent reproducibility even for highly challenging shallow gradients was determined, confirming the 1290 Infinity II Bio LC as the next generation of Agilent high-end liquid chromatography systems for high confidence in generated data.
使用 Agilent 8697 顶空进样器和 8850 GC-FID 系统进行制药行业的残留溶剂分析
利用透射拉曼光谱对软凝胶胶囊进行定量与鉴定测试
检测婴儿配方奶粉、牛奶和鸡蛋中的 30 种全氟烷基和多氟烷基化合物
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
