方案下载应用领域 | 环保 |
检测样本 | 废水 |
检测项目 | 有机污染物>烃类化合物 |
参考标准 | / |
Abstract This application note evaluates the performance of an Agilent 8890/5977C gas chromatography/mass selective detector (GC/MSD) in the analysis of semivolatile organic compounds (SVOCs) at both traditional and enhanced sensitivity levels. The GC/MSD system was initially calibrated with a range of 0.2 to 150 μg/mL with 97% of the 76 evaluated analytes meeting the requirement for average response factor (RF) curve fits. Method modifications to enhance sensitivity were applied to challenge a lower calibration range of 0.01 to 10 μg/mL. Under these amended conditions, 97% of the tested compounds also met or exceeded the United States Environmental Protection Agency (US EPA) Method 8270E criteria for average RF fits. These results demonstrated a potential for lower detection of analytes.
Introduction
The analysis of semivolatile organic compounds (SVOCs) provides a critical evaluation of our environment for persistent pollutants. The United States Environmental Protection Agency (US EPA) has issued regulations and guidelines in Method 8270E1 for the analysis of these analytes by gas chromatography/mass spectrometry (GC/MS). The analysis of SVOCs as a class comes with challenges and is a reasonable method of testing the performance of a GC/MS platform. The diverse set of analytes include phthalates, phenols, nitrosamines, aromatic nitro compounds, and polynuclear aromatic hydrocarbons (PAHs), among others. These analytes span a wide range of molecular weights and have a wide range of vapor pressures. Some of the analytes are well disposed to analysis by gas chromatography while others present significant challenges relating to stability,reproducibility, and chromatographic integrity.
使用 Agilent 5800 ICP-OES 测定固态 电解质锂镧锆钽氧 (LLZTO) 中的 主量元素
Agilent Vaya 手持式拉曼光谱仪的 不透明容器分析能力
使用 Agilent 8890 气相色谱和 TCD/FID 系统分析氢气中的氦气、 氩气、氮气和烃类杂质
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
