方案下载应用领域 | 环保 |
检测样本 | 饮用水 |
检测项目 | |
参考标准 | / |
Abstract An Agilent 8890/5977C GC/MSD system coupled with an Agilent 8697 headspace sampler was successfully used with hydrogen carrier gas for the analysis of volatile organic compounds (VOCs) in drinking water. Recent concerns with the price and availability of helium have led laboratories to look for alternative carrier gases for their GC/MS methods. For GC/MS, hydrogen is the best alternative to helium, and offers potential advantages in terms of chromatographic speed and resolution. However, hydrogen is not an inert gas, and may cause chemical reactions in the mass spectrometer electron ionization (EI) source. This can lead to disturbed ion ratios in the mass spectrum, spectral infidelity, peak tailing, and nonlinear calibration for some analytes. Therefore, a new EI source for GC/MS and GC/MS/MS was developed, and optimized for use with hydrogen carrier gas. The new source, named HydroInert, was used in the system evaluated here. In addition to the new source, the chromatographic conditions were optimized to provide separation of 80 volatile compounds in 7 minutes. Standards and samples were analyzed in both scan and SIM data acquisition modes. For the scan data, spectra were deconvoluted with MassHunter Unknowns Analysis software and searched against NIST 20 to assess the spectral fidelity. In both modes, quantitative calibration was performed for the 80 compounds over the range of 0.05 to 25 μg/L. As demonstrated in this note, the system gives excellent results for the analysis of VOCs in drinking water.
Introduction
One of the analyses commonly used to ensure that the quality of drinking water is the measurement of volatile organic compounds (VOCs). These compounds can appear in drinking water by contamination from numerous sources, including industrial and commercial operations. Another common source is when VOCs are formed by the addition of chlorine (used to disinfect the water), and react with natural organic matter in the source water. Regulations governing the allowable concentration of VOCs in drinking water vary by country and
region, but are typically in the low μg/L (ppb) range. Due to the large number of potential contaminants, and the need to measure them at such low levels, GC/MS systems are commonly
used. GC/MS offers both the sensitivity and selectivity required to identify and quantify VOCs. Purge and trap1 and static headspace2,3 are two commonly used automated sampling techniques that extract the VOC analytes from water samples and inject them into the GC/MS. This application note describes a system configured to perform static headspace/GC/MS analysis of VOCs in drinking water, optimized for using hydrogen as the carrier gas.
使用 Agilent 5800 ICP-OES 测定固态 电解质锂镧锆钽氧 (LLZTO) 中的 主量元素
Agilent Vaya 手持式拉曼光谱仪的 不透明容器分析能力
使用 Agilent 8890 气相色谱和 TCD/FID 系统分析氢气中的氦气、 氩气、氮气和烃类杂质
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
