方案下载应用领域 | 环保 |
检测样本 | 固体废物 |
检测项目 | |
参考标准 | / |
Abstract Gas chromatography/mass spectrometry (GC/MS) is integral to the analysis of semivolatile organic compounds (SVOCs) in environmental matrices. Recent pressure on the helium (He) supply has required organizations to actively investigate hydrogen (H2) carrier gas, but most GC/MS analyses have reduced sensitivity and hydrogenation or dechlorination in the sources. The Agilent HydroInert source retains the ability to analyze a wide calibration range (0.1 to 100 μg/mL) and meet the U.S. Environmental Protection Agency (EPA) method 8270 calibration criteria when using H2 carrier gas.
Introduction
GC/MS is regarded as the select analytical technique for the analysis of SVOCs. Governmental regulatory authorities have established methods and performance criteria for the measurement of SVOCs identified as pollutants in nvironmental and industrial matrices. For example, the U.S. EPA method 8270 (versions 8270D and 8270E) contains a list of over 200 compounds suitable for analysis by GC/MS in solid waste, soil, air, and water extracts.1,2 Method 8270 contains SVOCs across several analyte class types from acids, bases, neutral compounds, and polyaromatic hydrocarbons (PAHs); this method also has detailed specifications and requirements for the Quantitative Analysis of SVOCs
使用 Agilent InfinityLab 在线液相色谱 系统实现对流动化学反应器中反应过 程的实时监测
使用配备氦气节省模块以进行载气 切换的 Agilent 8850 气相色谱系统 分析香草提取物的方法转换
应用 QuEChERS 方法结合 Agilent 7000 系列三重四极杆气质联用仪测定甜菜中 的多农药残留
CrossLab企业资产管理服务
Agilent 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
