方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Distilled spirits, wine, and beer all contain flavoring agents, esters, acids, and aldehydes. While the ethanol content is closely monitored and regulated by government agencies, the unique flavor of each spirit is the combination of the individual compounds. While other methods can determine the ethanol content, only Chromatography can messure the ethanol and separate the individual constituents for identification. When you want to know what makes your favorite bourbon, rum, or whiskey tastes so special you need a DPS Alcohol & Spirites GC System. The latest designed high resolution columns and the sensitive FID detector does the hard work for you. The fast heating and rapid cooling column oven in every DPS GC vastly increases your sample throughput. Adding a 110 vial Autosampler can increase your profits by running the system around the clock. The fully intergrated Alcohol & Spirits GC Analyzer System is small and lightweight and all DPS systems are modular for expandability, upgrades, and easy service.
用OSP解除SECM中高度的影响--在腐蚀中的应用
华洋科仪:用DPS气相色谱仪进行生物柴油分析
华洋科仪:DPS气相色谱仪专用环境气体分析方法
法国Bio-Logic 电化学工作站VSP-300(6通道)
法国Bio-Logic 电化学工作站 HCV-3048 Booster
法国Bio-Logic 电化学工作站FlexP 0060/0012
法国Bio-Logic高电流电化学工作站HCP-803
法国Bio-Logic高精度多通道电池测试系统MPG-2XX
法国Bio-Logic 电化学工作站SP-150e(双通道)
法国Bio-logic 电化学工作站SP-50e(单通道)
SIS-5100光波导光谱仪
全自动微孔板检测圆二色光谱仪
法国Bio-Logic 电化学工作站 VSP-3e(8通道)
法国Bio-Logic微区扫描电化学工作站M470
Bio-Logic圆二色光谱仪MOS-500
BioTools振动圆二色光谱仪ChiralIR-2X
BioTools手性拉曼光谱仪ChiralRAMAN-2X
法国Bio-Logic 电化学工作站 VMP-3e(16通道)
