方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Water-gas-shift (WGS) reaction rates have been measured on Pd/ceria, Ni/ceria, Fe/ceria, Co/ceria, ceria, and Pd/silica.Pd/ceria exhibited much higher activities than either ceria alone or Pd/silica, demonstrating a cooperative effect between Pd and ceria. Pd/ceria and Ni/ceria showed essentially the same activities and were much more active than either Co/ceria or Fe/ceria. Reaction orders on Pd/ceria were approximately zeroth-order in CO, half-order in H2O, inverse-half-order in CO2 and inverse-first-order in H2. Diffuse reflectance, FTIR measurements on Pd/ceria indicate the ceria exists in a reduced state under WGS conditions and is covered by carbonate species that are removed only by reoxidation of ceria. The implications of these results for improved WGS catalysis are discussed. © 2001 Elsevier Science B.V. All rights reserved.
用OSP解除SECM中高度的影响--在腐蚀中的应用
华洋科仪:用DPS气相色谱仪进行生物柴油分析
华洋科仪:DPS气相色谱仪专用环境气体分析方法
法国Bio-Logic 电化学工作站VSP-300(6通道)
法国Bio-Logic 电化学工作站 HCV-3048 Booster
法国Bio-Logic 电化学工作站FlexP 0060/0012
法国Bio-Logic高电流电化学工作站HCP-803
法国Bio-Logic高精度多通道电池测试系统MPG-2XX
法国Bio-Logic 电化学工作站SP-150e(双通道)
法国Bio-logic 电化学工作站SP-50e(单通道)
SIS-5100光波导光谱仪
全自动微孔板检测圆二色光谱仪
法国Bio-Logic 电化学工作站 VSP-3e(8通道)
法国Bio-Logic微区扫描电化学工作站M470
Bio-Logic圆二色光谱仪MOS-500
BioTools振动圆二色光谱仪ChiralIR-2X
BioTools手性拉曼光谱仪ChiralRAMAN-2X
法国Bio-Logic 电化学工作站 VMP-3e(16通道)
