方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Differential steam-reforming rates were measured for methane, ethane, n-butane, n-hexane, 2,4-dimethylhexane, n-octane, cyclohexane, benzene, and toluene over 1 wt.% Pd/ceria between 620 and 770K and were compared to rates observed on 1 wt.% Pd/alumina and 1 wt.% Pt/ceria. The H2O:C ratios at which stable rates were observed on Pd/ceria depended on the hydrocarbon, varying from less than 1:1 for methane to 3:1 for 2,4-dimethylhexane. In the series of alkanes from methane to n-hexane, for a H2O:C ratio of 2:1, the only products were CO, CO2, and H2O and the rate of formation of CO2 and CO increased with carbon number. Benzene was also selectively converted to COx and H2, but at lower rates than the alkanes with the exception of methane. For 2,4-dimethylhexane and n-octane, a significant amount of cyclohexane was observed in the initial products and cyclohexane was selectively converted to benzene at low conversions. Steam reforming of toluene also gave benzene as the initial product. FTIR measurements of Pd/ceria under methane-steam-reforming conditions indicate the formation of carbonates on the ceria. Pd/alumina showed significantly lower rates than Pd/ceria and much lower CO2:CO ratios in the initial products, implying ceria plays an important role in the reaction. Pt/ceria gave rates and selectivities that were essentially identical to that of Pd/ceria. The implications of these results for hydrocarbon fuel processing are discussed. © 2002 Elsevier Science B.V. All rights reserved.
用OSP解除SECM中高度的影响--在腐蚀中的应用
华洋科仪:用DPS气相色谱仪进行生物柴油分析
华洋科仪:DPS气相色谱仪专用环境气体分析方法
法国Bio-Logic 电化学工作站VSP-300(6通道)
法国Bio-Logic 电化学工作站 HCV-3048 Booster
法国Bio-Logic 电化学工作站FlexP 0060/0012
法国Bio-Logic高电流电化学工作站HCP-803
法国Bio-Logic高精度多通道电池测试系统MPG-2XX
法国Bio-Logic 电化学工作站SP-150e(双通道)
法国Bio-logic 电化学工作站SP-50e(单通道)
SIS-5100光波导光谱仪
全自动微孔板检测圆二色光谱仪
法国Bio-Logic 电化学工作站 VSP-3e(8通道)
法国Bio-Logic微区扫描电化学工作站M470
Bio-Logic圆二色光谱仪MOS-500
BioTools振动圆二色光谱仪ChiralIR-2X
BioTools手性拉曼光谱仪ChiralRAMAN-2X
法国Bio-Logic 电化学工作站 VMP-3e(16通道)
