方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Carbon nanotubes known as a novel discovered form of carbon. They are also expected to be excellent adsorbents for adsorption of trace pollutants from water or air.The objective of this paper is to study adsorption characteristics of isopropyl alcohol (IPA) vapor in the range of 40-800 ppmv from air stream with single-walled carbon nanotubes (SWCNTs).The test results indicated that the nature of the SWCNTs surface was greatly improved after purification by concentrated hypochlorous acid, which made SWCNTs become more hydrophilic and suitable for adsorption of IPA vapor from air stream. A significantly higher adsorption capacity of IPA vapor was found with purified SWCNTs than with raw SWCNTs. The BET isotherm is the best model to describe adsorption behavior of IPA vapor onto purified SWCNTs, followed by the Freundlich isotherm, and then the Langmuir isotherm.
用OSP解除SECM中高度的影响--在腐蚀中的应用
华洋科仪:用DPS气相色谱仪进行生物柴油分析
华洋科仪:DPS气相色谱仪专用环境气体分析方法
法国Bio-Logic 电化学工作站VSP-300(6通道)
法国Bio-Logic 电化学工作站 HCV-3048 Booster
法国Bio-Logic 电化学工作站FlexP 0060/0012
法国Bio-Logic高电流电化学工作站HCP-803
法国Bio-Logic高精度多通道电池测试系统MPG-2XX
法国Bio-Logic 电化学工作站SP-150e(双通道)
法国Bio-logic 电化学工作站SP-50e(单通道)
SIS-5100光波导光谱仪
全自动微孔板检测圆二色光谱仪
法国Bio-Logic 电化学工作站 VSP-3e(8通道)
法国Bio-Logic微区扫描电化学工作站M470
Bio-Logic圆二色光谱仪MOS-500
BioTools振动圆二色光谱仪ChiralIR-2X
BioTools手性拉曼光谱仪ChiralRAMAN-2X
法国Bio-Logic 电化学工作站 VMP-3e(16通道)
