方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The barrier properties of coatings are vitally important in the protection of metals against corrosion. Water and ion ingression (e.g. Cl-), which penetrate to the metal/coating interface, generate electrochemically active sites and corrosion follows. Presently various experimental techniques, such as salt spray tests, are used to study corrosion protection properties of coatings and to predict their performance. However, most corrosion tests only provide a qualitative estimation of the protective properties of coatings without any information on the mechanism of protection or failure. Electrochemical Impedance Spectroscopy is widely used, not only to examine and rank the corrosion protection performance of coatings, but also to obtain important information on the kinetics of coating degradation and corrosion activity during exposure to a corrosive media. Localised scanning methods like the Scanning Vibrating Electrode Technique can be used to acquire localised electrochemical details that cannot be obtained by conventional techniques, which can shed yet more light on coating performance. Although the above techniques have all been used to investigate coatings, correlation between the results has not been conducted comprehensively.
用OSP解除SECM中高度的影响--在腐蚀中的应用
华洋科仪:用DPS气相色谱仪进行生物柴油分析
华洋科仪:DPS气相色谱仪专用环境气体分析方法
法国Bio-Logic 电化学工作站VSP-300(6通道)
法国Bio-Logic 电化学工作站 HCV-3048 Booster
法国Bio-Logic 电化学工作站FlexP 0060/0012
法国Bio-Logic高电流电化学工作站HCP-803
法国Bio-Logic高精度多通道电池测试系统MPG-2XX
法国Bio-Logic 电化学工作站SP-150e(双通道)
法国Bio-logic 电化学工作站SP-50e(单通道)
SIS-5100光波导光谱仪
全自动微孔板检测圆二色光谱仪
法国Bio-Logic 电化学工作站 VSP-3e(8通道)
法国Bio-Logic微区扫描电化学工作站M470
Bio-Logic圆二色光谱仪MOS-500
BioTools振动圆二色光谱仪ChiralIR-2X
BioTools手性拉曼光谱仪ChiralRAMAN-2X
法国Bio-Logic 电化学工作站 VMP-3e(16通道)
