SFM300应用资料3
2012/12/12   下载量: 7
方案下载
应用领域
检测样本
检测项目
参考标准
We report on novel type of responsive double hydrophilic block copolymer (DHBC)-based multifunctional chemosensors to Hg2þ ions, pH, and temperatures and investigate the effects of thermo-induced micellization on the detection sensitivity. Well-defined DHBCs bearing rhodamine B-based Hg2þ -reactive moieties (RhBHA) in the thermoresponsive block, poly(ethylene oxide)-b-poly(N-isopropylacrylamide-co-RhBHA) (PEO-b-P(NIPAM-co-RhBHA)), were synthesized via reversible addition-fragmentation chain transfer (RAFT) polymerization. Nonfluorescent RhBHA moieties are subjected to selective ring-opening reaction upon addition of Hg2þ ions or lowering solution pH, producing highly fluorescent acyclic species. Thus, at room temperature PEO-b-P(NIPAM-co-RhBHA) DHBCs can serve as water-soluble multifunctional and efficient fluorescent chemosensors to Hg2þ ions and pH. Upon heating above the lower critical solution temperature (∼36 C) of thePNIPAM block, they self-assemble into micelles possessing P(NIPAM-co-RhBHA) cores and well-solvated PEO coronas, which were fully characterized by dynamic and static laser light scattering. It was found that the detection sensitivity to Hg2þ ions and pH could be dramatically improved at elevated temperatures due to fluorescence enhancement of RhBHA residues in the acyclic form, which were embedded within hydrophobic cores of thermo-induced micellar aggregates
方案下载
配置单
上一篇 用OSP解除SECM中高度的影响--在腐蚀中的应用
下一篇 SFM300应用资料4
文献贡献者
华洋科仪
金牌会员第23年
查看全部资料
相关方案
当前位置: 华洋科仪 方案 SFM300应用资料3
