SFM300应用资料5
2012/12/12   下载量: 5
方案下载
应用领域
检测样本
检测项目
参考标准
We have comparatively studied the association of cyclic- and linear-poly(N-isopropylacrylamide) (c-PNIPAM and l-PNIPAM) chains with varying chain lengths and end groups in dilute aqueous solutions by laser light scattering (LLS) and stopped-flow temperature-jump measurements. Dynamic and static LLS results reveal that the heating leads to a microphase transition. The resultant structures of interchain aggregates depend on the heating rate and the chain topologies. In comparison with l-PNIPAM chains, a slow heating of c-PNIPAM chains in the solution results in stable mesoglobules with a lower average aggregation number, a looser structure, and a smaller average size (∼290 nm). The temperature-jump-induced association of c-PNIPAM chains in the stopped-flow measurement reveals two kinetic growth stages, which were tentatively ascribed to the loose packing of contracted c-PNIPAM chains and further contraction-induced fragmentation of initially packed c-PNIPAM chains due to the lack of interchain entanglements. On the other hand, for l-PNIPAM chains, the intrachain contraction and interchain penetration/entanglement simultaneously occur as the temperature increases, leading to larger and more compact aggregates whose size increases with the solution temperature.
方案下载
配置单
上一篇 用OSP解除SECM中高度的影响--在腐蚀中的应用
下一篇 SFM300应用资料6
文献贡献者
华洋科仪
金牌会员第23年
查看全部资料
相关方案
当前位置: 华洋科仪 方案 SFM300应用资料5
