方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
With regard to the increasing necessity for researcher to have discriminating methods. Electrochemical techniques could not easily be used alone anymore. Instruments for electrochemical studies must be able to be connected to other external instruments. Coupled with other analytical methods. Electrochemistry becomes a powerful characterizing method. For example, polypyrrol films have often and widely been studied by an electrochemical way especially the electropolymerisation process. The only use of electrochemistry is not now sufficient to explain the whole electropolymerisation process. One can easily understand the interest of coupled method in studying species with spectroscopic properties. Electrochemistry coupled with spectroscopic methods is now an usual combination of discriminating techniques for polypyrrol study. Coupling methods often result in technical and assembling problems to synchronize the electrochemical experiment and the external measurement and to record external variables. These are the main user''s needs.
用OSP解除SECM中高度的影响--在腐蚀中的应用
华洋科仪:用DPS气相色谱仪进行生物柴油分析
华洋科仪:DPS气相色谱仪专用环境气体分析方法
法国Bio-Logic 电化学工作站VSP-300(6通道)
法国Bio-Logic 电化学工作站 HCV-3048 Booster
法国Bio-Logic 电化学工作站FlexP 0060/0012
法国Bio-Logic高电流电化学工作站HCP-803
法国Bio-Logic高精度多通道电池测试系统MPG-2XX
法国Bio-Logic 电化学工作站SP-150e(双通道)
法国Bio-logic 电化学工作站SP-50e(单通道)
SIS-5100光波导光谱仪
全自动微孔板检测圆二色光谱仪
法国Bio-Logic 电化学工作站 VSP-3e(8通道)
法国Bio-Logic微区扫描电化学工作站M470
Bio-Logic圆二色光谱仪MOS-500
BioTools振动圆二色光谱仪ChiralIR-2X
BioTools手性拉曼光谱仪ChiralRAMAN-2X
法国Bio-Logic 电化学工作站 VMP-3e(16通道)
