An Educational Webinar
April 20 & 21, 2016*
Session 1 on April 20 - 3pm Beijing Time
Session 2 on April 21 - 3pm Beijing Time
注册方法
方法一:
请将以下网址复制粘贴至浏览器内,即可直接转到布鲁克官网注册
https://www.bruker.com/service/education-training/webinars/nmr-webinars/foodscreenertmnmr.html
方法二(更快捷):
请将以下网址复制粘贴至浏览器内,可直接注册 Session 1 (北京时间 2016年4月20日下午3点)
http://mc.bruker.com/acton/form/5109/0144:d-0004/0/-/-/-/-/index.htm
请将以下网址复制粘贴至浏览器内,可直接注册 Session 2 (北京时间 2016年4月21日下午3点)
http://mc.bruker.com/acton/form/5109/0145:d-0003/0/-/-/-/-/index.htm
* The sessions are identical
Seminar Overview
所有传统的食品检测方法都是靶向的。缺点在于,传统检测方法会漏过未知或未预测到的标志物,从而造成结果的假阴性。基于核磁共振(NMR)的筛选方法可以实现非靶向检测。
FoodScreenerTM是Bruker研发的基于400MHz NMR波谱的食品分析标准化平台。其原理是基于每一个样品独特的NMR指纹图谱。该产品特性如下:
全自动按键式解决方案,包括自动生成结论评估和结果报告。
基于一次NMR采样,就能提供靶向和非靶向分析的可靠筛选方法。
通过聚类分析预测诸如品种、原产地和酿造年份等真实性参数。
几十种代谢物的定量结果,定量结果与官方参考值比较,所有化合物的浓度结果与真实样品库的浓度分布比较,从而为结果的解析提供支持。
通过模型验证的方法,将样品与真实葡萄酒参考数据库进行比较,从而完成样品合格与否的非靶向验证。
Webinar将会对基于NMR的Food Screener方法进行讲解,并举例说明。
Presenters
Dr. Wenxin Xu (biography) - Application Specialist.
Biographical Information
Dr. Wenxin Xu
Wenxin Xu was graduated from Wuhan institute of physics and mathematics, Chinese Academy of Science as Ph.D. The involved academic project is concerning NMR based metabonomics to explore the underlying metabolic mechanism of progressive development of diseases and to investigate drug/toxicant induced metabonome variarations. After that, she joined in Bruker China as NMR Application specialist 5 years ago.
Dr. Lu Shan (biography) - Application Specialist.
Dr. Lu Shan
Lu Shan was graduated from institute of biophysics, Chinese Academy of Science as Ph.D. The involved academic project is concerning Solution NMR study of protein 3D structure. After that, he joined in Bruker China as NMR Application specialist 11 years ago.
【参会邀请】2024布鲁克核磁共振制药应用交流会:日程已更新!
布鲁克与国家蛋白质设施签订合作协议,共同推进高场核磁蛋白质研究
【新闻动态】布鲁克在韩国基础科学研究院(KBSI)成功安装1.2 GHz Avance核磁共振波谱仪
Andrew Webb和Bernhard Blümich教授荣获Richard R. Ernst大奖
布鲁克台式核磁共振波谱仪Fourier 80
布鲁克电子自旋共振波谱仪microESR
布鲁克600MHz核磁共振NMR波谱仪 AVANCE NEO 600M
布鲁克500MHz核磁共振波谱仪 AVANCE NEO 500M
布鲁克400MHz核磁共振NMR波谱仪 AVANCE NEO 400M
布鲁克台式电子顺磁波谱仪Magnettech ESR5000
布鲁克 LabScape Service & Lifecycle Su
布鲁克固体核磁探头续用 A2B 改装套件
布鲁克 AVANCE NEO 核磁共振 (NMR) 波谱仪
布鲁克SkyScan1276X射线显微断层成像
布鲁克 mq-ProFiler时域核磁共振分析仪
布鲁克minispec mq系列时域核磁共振分析仪
布鲁克时域核磁共振液滴粒径分析仪
布鲁克 minispec LF90II身体组分分析仪
布鲁克 minispec 碳氢化合物含氢量测定
