方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
To improve detection limits for elements such as Hg, As, Sb, Se and Sn, one can use hydride generation. This is particularly useful for environmental analysis, where the concentration ranges are close to the μg/L level. One of the main drawbacks of this technique, until recently, has been the requirement of performing the analysis twice: once for the normal elements and the other for the hydride species. Additionally, it was necessary to replace the standard spray chamber system with a hydride generator device. With the CMA, it is not necessary to change anything. Using the same conditions and cassette, all the normal elements and hydride species can be determined in one analysis run and the detection limits are improved by a factor of 5 to 50 for the hydride forming elements.
拉曼+石墨烯+振动探测
拉曼+二维材料+应变工程
拉曼+CO2加氢反应+催化机理
HORIBA XploRA Nano原子力-拉曼联用系统
HORIBA高灵敏一体式FluoroMax-4荧光光谱仪
HORIBA Fluorolog®-3科研级荧光光谱仪
HORIBA XploRA INV多功能拉曼及成像光谱仪
HORIBA EMGA-Expert 氧氮氢分析仪
HORIBA EMGA-Pro氧氮氢分析仪
HORIBA 离心式粒度分析仪Partica CENTRIFUGE CN-300
HORIBA Fluorolog-QM模块化科研级稳瞬态荧光光谱仪
ViewSizer 3000 纳米颗粒追踪分析仪
HORIBA LabRAM Odyssey 高速高分辨显微共焦拉曼光谱仪
HORIBA LabRAM Soleil™高分辨超灵敏智能拉曼成像仪
HORIBA NANO Raman
HORIBA XGT-9000 X射线显微分析仪
HORIBA Duetta荧光及吸收光谱仪
HORIBA MacroRAM 台式一体化拉曼光谱仪
