德国IKA实验室反应器(反应釜)
LR-2.ST 和LR 2000系统是模块化可扩展的实验室反应釜。设计在实验室规模生产和优化化学反应过程,如混合,分散,匀浆等。
应用于下述行业:
· 制药行业和化妆品行业,生产乳酪,洗液,乳液以及脂制体制备
· 将固体,如碳酸钙,滑石粉,氧化钛等与乳液混合
· 将添加剂和固体聚合物与矿物油混合
· 在液体和聚合物中研磨和分解固体和纤维
性价比高的LR-2.ST实验室反应釜可用于真空操作。
实验室反应釜系列LR 2000 P(压力)和LR 2000 V(真空)专门用在制药和化妆品行业。
系统可以进行单独的改动,以适应不同的需要。可配置IKA的实验室设备,如温度和pH测量设备,实验室搅拌机和分散设备,泵和恒温水浴等,也可以和PC连接,通过labworldsoft软件进行控制。也可以配置扭距测量设备VK 600 control VISCOKLICK或者VM 600 basic 检测流变学特性。
LR-2.ST IKA Lab reactor system - 8016500
The LR-2.ST system is a modulary designed miniplant reactor system, planned and designed to simulate and optimize chemical reaction processes as well as mixing, dispersion and homogenization processes at a model scale with maximum volume 2000 ml.
Depending on the seal (FFPM, FPM), the medium in the reactor vessel can be heated up to 230 癈 Vacuum operation is possible up to 25 mbar.
Adapting the VM 600 basic Visco module (accessory) makes it possible to evaluate rheological properties of the materials such as viscosity, flow and deformation behavior with additional torque measurements.
Chemical engineering applications with the LR 2000...
Designed and configured for simulating and optimizing chemical reaction processes as well as mixing, dispersing, and homogenizing processes on a smaller scale.
Typical examples of such development tasks are:
manufacturing cremes, lotions, emulsions, liposome preparations in the pharmaceutical and cosmetic sector
mixing solids such as calcium carbonate, talc, titanium oxide, etc. into liquid polymers
mixing additives and solid polymer compounds into mineral oils
grinding and disintegrating solids and fibers in liquids and polymers
阅读734次
已关注
