技术参数 1.输入功率:1.8 kW2.外形尺寸( W x D x H):440 x 450 x 500 m m3.测量范围:最大40,000 J4.测量重复性:苯甲酸NBS 39i 动态 0.1% RSD5.KV 500冷却水系统
主要特点1.自动水控制系统,包括温度调节,量热仪内腔填充与清空2.分解氧弹自动冲氧,分解氧弹自动识别3.自动样品点火4.紧凑的,模块化的设计,容易操作5.提供天平和打印机接口,打印机,监视器和C5020 样品架接口;使用多接口卡,单台电脑可控制多达8个测量单元
仪器介绍C2000 标准型,控制型和C2000耐高压型C2000标准型和C2000控制型是IKA最新的测量液体和固体样品热值的系统。 仪器具有高度的自动化,而且操作简便。除了周边等温测量过程,用户还可以选择快速动态工作模式(缩短测量时间)。结合特别的C5012系列防卤素分解氧弹,在分析总热值的同时,使硫和卤素成分得到定量的分解。 C2000量热仪的冷却水提供,可以连接市场上标准的自动恒温器,如KV 500(131页),或者是连接到适当的固定水源。 C2000 标准型 配置有一个非常方便的操作面板来操作仪器。 C2000 控制型 出厂已包含C5040 Calwin 量热计软件。用串口把电脑和C2000 量热计连接起来就可实现控制。网络连接和特殊的数据交换可通过LIMS随时实现。 C2000高压型结合了C2000标准型和分解坩埚C 62(131页)。 C2000提供给用户的是具有优良性能价格比的仪器。
C 2000 basic - 8801800 Price: On Request Calorimeter system?C2000 basic The C2000 basic / control calorimeter is the latest system from IKA? for determining gross calorific values of liquids and solid fuels. During the development of this calorimeter, great importance was placed on user-friendliness and on simple and fast maintenance. A higher level of automation with extremely simple handling characterizes this device. In addition to the isoperibolic measurement procedure, a dynamic (reduced-time) working method is also available for the user. Different working temperatures can be selected for both procedures based on the conditions of the experiment. Both the device technology and the measurement procedure are approved by DIN 51900, ASTM 240D, ISO 1928 and BSI. In combination with special halogen-resistant decomposition vessels of the C5012 series, quantitative decompositions can be performed in parallel to the analysis of gross calorific value to determine halogen and sulfur content. To provide a supply of cooling water, the C2000 calorimeter is connected with a standard commercially available thermostat or with an appropriate permanently installed water connection. The C2000 Basic is equipped with a very convenient operating panel through which operation of the device takes place. The graphical display with active back lighting displays the appropriate status messages. The temporal course of a measurement that has been started and all current parameters of the weighed in sample can be constantly monitored and are arranged to be clearly visible. Library functions and various correction modes make it possible to call up measurements that have already been performed at any time and to edit post-experiment parameters. The C2000 basic / control calorimeter is equipped with a separate service menu that allows for fast access to individual maintenance functions and testing of basic system data. Connections for analysis scale, printer, sampleample rack for identifying and managing samples are already integrated into the basic device. The network connection and the special configuration for data exchange can be implemented at any time with LIMS. Included with delivery: Version 1 · C 2000 measuring cell with control and evaluation unit · C 5010 decomposition vessel, standard Version 2 · C 2000 measuring cell with control and evaluation unit · C 5012 decomposition vessel, halogen resitant Further information: Manual Literature
阅读1672次
已关注
