方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Extraction of nucleic acids from plants is a time consuming and labor intensive process. Two common methods of extraction are (i) grinding individual samples with mortar and pestle, and (ii) mechanical mincing. Unfortunately, these methods are prone to contamination, as the same tools are often reused sequentially for multiple preparations. This risk of contamination is often unacceptable, especially in studies using rare or valuable specimens, such as when breeding selection is critical (particularly with the advent of genetically engineered crops), or when intellectual property discovery or protection is involved. Here we compare cell isruption by Qiagen RNeasy with mortar and pestle to pressure cycling technology PCT) for the extraction of RNA from corn sprouts, grape seeds, and grape skin. 利用压力循环技术(PCT)从植物组织中提取RNA 从植物中提取核酸是一件非常耗时耗力的工作。目前常见的提取方法有人工研磨和机械破碎两种方法。因为研磨工具和破碎刀头经常反复使用,所以这两种方法非常容易造成污染。在对非常稀少或者非常有价值的样品进行研究时,污染常常不能被接受。本文介绍了利用压力循环技术(PCT)和传统研磨技术两种不同的方法从玉米芽、葡萄种子和葡萄皮中提取RNA,并对这两种方法进行了比较。
【CEM】电子设备组件样品制备用于IEC 62321-7-2:2017方法六价铬含量分析
【eralytics】结合蒸气压与密度的测量
【CEM】环状二硫键桥肽的全自动合成
CEM Mars6 高通量密闭高压微波消解仪
EDGE全自动快速溶剂萃取仪
CEM MARS-X 微波溶剂萃取系统
ISCO X系列高压高精度柱塞泵
Hanson 6/8杯药物溶出度仪
ISCO 快速制备液相色谱仪
Katanax X600重型电熔样机/熔融炉/熔片机
CEM Smart 6 通用微波水分测量仪
Hanson 14杯药物溶出度仪
CEM Discover 2.0 300mL腔体环形聚焦单模微波合成仪
SPEX大容量液氮冷冻研磨仪
CEM ORACLE通用快速脂肪分析仪
HG-600 Geno/Grinder (原SPEX 2010)高通量动植物组织研磨机
SPEX BM-400/450高能量球磨机(原SPEX 8000M/D)
SPEX CG-500高通量液氮冷冻研磨仪(SPEX 6875D)
