方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
KEYWORDS Thermal Desorption, Tenax TA™, Sample drying, Herbs, PeppersABSTRACT The analysis of volatiles in solids is a common analytical problem. Examples include volatile aroma compounds in foods (coffee, tea, herbs), residual fragrances from soaps and fabric softeners on textiles, and volatiles in polymer resins, films and plastic products. When high sensitivity analysis is needed, many of these sample types can be analyzed by direct thermal desorption with cryotrapping before the GC column. A wide variety of sample types can contain significant levels of water. This poses significant challenges when doing direct thermal desorption and cryotrapping for analysis of volatiles, since water can accumulate and freeze in an inlet or at the head of a column. Introduction of significant levels of water into the GC column can degrade chromatographic performance and shorten column lifetime. There are several strategies that are useful to reduce the introduction of water into a GC when doing thermal desorption. These range from offline thermal extraction with trapping of volatiles on adsorbent beds to incorporating drying steps into the thermal desorption process itself. Estimating the amount of water that can be eliminated with each of these approaches is a challenge. Volatiles in solid samples containing up to 90% water were analyzed by direct thermal desorption incorporating different drying strategies. Offline thermal extraction utilizing Tenax TA™ adsorbent was the most effective approach for eliminating large amounts of water while effectively retaining low boiling analytes. Small amounts of water (tens of milligrams) can be eliminated from samples by using Tenax TA™ packed inlet liners cooled to 20-40°C. General guidelines for choosing appropriate steps for eliminating different levels of water are summarized.
Vapourtec系统安全扩大重氮盐和叠氮化物连续流合成规模
Vapourtec辅助抗疟疾药青蒿素高效合成
香豆酸甲酯的光化学转化
英诺德INNOTEG EasyPrep MP中压制备色谱(自动过柱机)
英诺德平行合成仪EasySyn-12
INNOTEG磁力搅拌器WM-1
Biopharma Technology冻干显微镜LyoStat5
英国Genevac真空离心浓缩仪miVac DNA
美国SP Scientific冻干机
德国Hettich微量管离心机MIKRO200R
英国Genevac HT 3i系列溶剂蒸发工作站
平行浓缩仪GenevacEZ-2 4.0溶剂蒸发工作站
英国GeneVac 快速溶剂蒸发系统 Rocket Synergy2
Lauda ECO加热制冷恒温浴槽
德国Lauda Alpha加热制冷恒温器
美国pickering 柱后衍生化仪器
气体采样器SAMPLING CASE
浓缩仪英国GeneVac miVac真空离心浓缩仪QUATTRO系列
