方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
An Introduction to Microindentation Methods Hardness – Perhaps Our Oldest Test At a time when companies are seeking to quantify and document virtually every process, a renewed interest has appeared in some of the old standbys such as hardness testing. Hardness testing is a proven quality control and inspection tool; it can be used to quickly determine if an incoming product meets specification or if a heat treatment was properly done. Hardness, as a mechanical property, is best defined as resistance to penetration or permanent deformation. The application of the hardness value, however, is specific to different professions: to a mechanical engineer it relates to the wear resistance; to a design engineer it relates to the flow stress, to a mineralogist it relates to the scratch resistance, and to a machinist it relates to the cutting rate.
标乐先进的制样技术-Mg及其合金制备
标乐先进的制样技术-汽车车身点焊样品制备
标乐先进的制样技术-片状多层陶瓷电容制样经验分析
洛氏硬度计 RH2150 | 美国威尔逊硬度计 Wilson
美国标乐 Buehler | SimpliVac 真空镶嵌机
美国标乐 Buehler | AbrasiMet M 手动砂轮切割机
Buehler AbrasiMet XL Pro™ 大型砂轮切割机
AutoMet™ 300 Pro 研磨抛光机
多功能硬度计 UH4000 | 美国威尔逊硬度计 Wilson
美国标乐 Buehler | AutoMet™ 250 研磨抛光机
美国标乐 Buehler | EcoMet 30 磨抛机
PlanarMet™ 300台式预磨机
MiniMet 1000 半自动磨抛机
美国标乐 Buehler | IsoMet HS 高速精密切割机
美国标乐 Buehler | SimpliMet 4000自动镶嵌机
全自动维氏/努氏硬度计 VH3300 | 美国威尔逊硬度计
DiaMet 硬度测试软件
IsoMet 1000精密切割机
