方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The high dewetting abilities of lotus leaves can be transited to a complete wetting state by soaking the leaves in water at a depth of 50 cm for 2 h. However, after being dried by N2 gas, the high dewetting behavior of lotus leaves may be mostly restored. This indicates that experimental procedure might considerably affect the dewetting abilities of lotus leaves. To discover the mechanism underlying this interesting dewetting phenomena, the dewetting force was used to characterize the dewetting abilities of surfaces, and model studies to mimic the papillae were done. Surface hydrophobicity, sizes, rise angles, and secondary structures of the models’ sides affected their dewetting force with water. So we suggested that the dewetting states, Cassie or Wenzel’s state, of lotus surfaces depend much on the depth of water, i.e., the hydraulic pressure. On the other hand, the primary structures of papillae in Cassie’s state led to a high receding angle with respect to the plane of the leaf during the dewetting measurement. The secondary structures and micro/nano arrays of papillae increased the dewetting abilities of lotus leaves, since no water intruded between papillae. However, the structures of papillae in Wenzle’s state significantly reduced the dewetting abilities of lotus leaves after being soaked at a depth of 50 cm for 2 h. Therefore, as for novel designs of microdevices floating on water, including the use of the high dewetting properties of suphydrophobic materials, surface (primary or secondary) microstructure and external pressure, such as static hydraulic pressure, must be taken into account.
改进的Washburn法研究矿物岩石颗粒的表面润湿性
接触角测量仪---如何方便地测量墨水、油墨、涂料等的接触角和表面张力
FOAMSCAN泡沫分析仪表征外部设备产生的泡沫特性
法国泰克利斯(TECLIS)高温泡沫分析仪(泡沫扫描仪) FOAMSCAN HTMP
泰克利斯(TECLIS)界面流变仪(界面张力仪) TRACKER HTHP
泰克利斯(TECLIS)高温高压界面流变仪(表面张力仪) TRACKER H
法国泰克利斯(TECLIS)界面流变仪(表面张力仪)TRACKER
法国泰克利斯(TECLIS)泡沫分析仪FOAMSCAN
微观可视化驱油工作站
德国劳达LAUDA Scientific光学粘滞力测量仪LSA100DARF
德国劳达LAUDA Scientific粉末接触角测量仪LSA100POM
在线接触角测量仪
双视接触角测量仪
手持便携式接触角测量仪
LSA MOB-X俯视法接触角测量仪
德国BOROSA高温高压悬滴法张力测量系统L 800
德国BOROSA常压声悬浮系统L200
德国BOROSA L800 高温高压声悬浮系统
