方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The Gemini surfactant 9B-4-9B containing sodium sulfonate as hydrophilic head group was synthesized based on nonylphenol and characterized by FTIR, 1H NMR spectroscopy and the surface tension measurement. The CMC and C20 of the 9B-4-9B were smaller than that of sodium dodecylbenzene sulfonate and sodium dodecylsulfate, respectively, indicating excellent efficiency of micelle formation and reduced surface tension. Conducting polyaniline salts were synthesized by chemical oxidative micellar polymerization of aniline in water firstly using Gemini surfactant 9B-4-9B as the micelle stabilizer and ammonium peroxydisulfate as the oxidant at 0 C. The stable polyaniline dispersions have been obtained when the molar ratio of the 9B-4-9B to aniline was equal to or above 0.5 used in the polymerization system. The obtained granular polyaniline particles with the size of 1–2 lm were characterized by FTIR, UV–Vis, SEM, WAXD and conductivity measurement.
改进的Washburn法研究矿物岩石颗粒的表面润湿性
接触角测量仪---如何方便地测量墨水、油墨、涂料等的接触角和表面张力
FOAMSCAN泡沫分析仪表征外部设备产生的泡沫特性
法国泰克利斯(TECLIS)高温泡沫分析仪(泡沫扫描仪) FOAMSCAN HTMP
泰克利斯(TECLIS)界面流变仪(界面张力仪) TRACKER HTHP
泰克利斯(TECLIS)高温高压界面流变仪(表面张力仪) TRACKER H
法国泰克利斯(TECLIS)界面流变仪(表面张力仪)TRACKER
法国泰克利斯(TECLIS)泡沫分析仪FOAMSCAN
微观可视化驱油工作站
德国劳达LAUDA Scientific光学粘滞力测量仪LSA100DARF
德国劳达LAUDA Scientific粉末接触角测量仪LSA100POM
在线接触角测量仪
双视接触角测量仪
手持便携式接触角测量仪
LSA MOB-X俯视法接触角测量仪
德国BOROSA高温高压悬滴法张力测量系统L 800
德国BOROSA常压声悬浮系统L200
德国BOROSA L800 高温高压声悬浮系统
