方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
A novel method to fabricate and tune cell membrane mimetic surfaces was developed based on the use of an amphiphilic random copolymer bearing phosphorylcholine (PC), stearyl and crosslinkable trimethoxysilylpropyl groups synthesized by free radical copolymerization. The polymer was coated on glass coverslips by dip-coating. The coated films were treated in water allowing reorganization of the surface groups to mimic the structure of cell outer membranes. This structure was fixed by crosslinking of the trimethoxysilylpropyl groups linked to the copolymer chains, as ascertained by dynamic contact angle (DCA) and attenuated total reflectance infrared spectroscopy (ATR-FTIR) measurements. Our results indicate that the surface structure can be tuned to a great extent to obtain a stable outer membrane mimetic surface/interface.
改进的Washburn法研究矿物岩石颗粒的表面润湿性
接触角测量仪---如何方便地测量墨水、油墨、涂料等的接触角和表面张力
FOAMSCAN泡沫分析仪表征外部设备产生的泡沫特性
法国泰克利斯(TECLIS)高温泡沫分析仪(泡沫扫描仪) FOAMSCAN HTMP
泰克利斯(TECLIS)界面流变仪(界面张力仪) TRACKER HTHP
泰克利斯(TECLIS)高温高压界面流变仪(表面张力仪) TRACKER H
法国泰克利斯(TECLIS)界面流变仪(表面张力仪)TRACKER
法国泰克利斯(TECLIS)泡沫分析仪FOAMSCAN
微观可视化驱油工作站
德国劳达LAUDA Scientific光学粘滞力测量仪LSA100DARF
德国劳达LAUDA Scientific粉末接触角测量仪LSA100POM
在线接触角测量仪
双视接触角测量仪
手持便携式接触角测量仪
LSA MOB-X俯视法接触角测量仪
德国BOROSA高温高压悬滴法张力测量系统L 800
德国BOROSA常压声悬浮系统L200
德国BOROSA L800 高温高压声悬浮系统
