方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The deposition of coatings on the surface of three-dimensional braided carbon fiber reinforced epoxy (C3D/EP) composites will be helpful to their applications. However, they are unsuitable to be deposited due to their low surface free energies, poor wettabilities and poor adhesions. Since treatment of polymers or composites by nonthermal plasmas is a fast, versatile and environmentally friendly surface modification technique, the plasma treatment of C3D/EP composites is investigated in this paper. Dielectric barrier discharges (DBD) in ambient air are used. C3D/EP (Vf=36%) sampleswith thickness of 2mmare placed into the plasma configuration. Time for plasma treatment is 30 s, 60 s and 120 s. The chemical and physical changes induced by the treatments on C3D/EP surface are examined using contact angle measurements, X-ray photoelectron spectroscopy (XPS) and atomic force microscopy (AFM). The water advancing contact angles of the plasma-treated C3D/EP samples change from 98.6° for the untreated sample to the lower value 45.7° after plasma treatment of 30 s and 42.7° of 120 s. XPS results reveal that the composites modified with the DBD at an atmospheric pressure show a significant increase in oxygen-containing and nitrogen-containing groups, such as C–O, O–C=O and NO2. The AFM images of the untreated and plasma-treated C3D/EP samples show that the composites surfaces roughen. The roughness of the untreated C3D/EP is 1.6 nm,while after plasma treatment of 30 s, 60 s and 120 s the values are 2.4 nm, 3.0 nm and 3.9 nm respectively. These results demonstrate that the surfaces of the C3D/EP samples are more active, hydrophilic and rough after plasma treatments using a DBD operating in ambient air.
改进的Washburn法研究矿物岩石颗粒的表面润湿性
接触角测量仪---如何方便地测量墨水、油墨、涂料等的接触角和表面张力
FOAMSCAN泡沫分析仪表征外部设备产生的泡沫特性
法国泰克利斯(TECLIS)高温泡沫分析仪(泡沫扫描仪) FOAMSCAN HTMP
泰克利斯(TECLIS)界面流变仪(界面张力仪) TRACKER HTHP
泰克利斯(TECLIS)高温高压界面流变仪(表面张力仪) TRACKER H
法国泰克利斯(TECLIS)界面流变仪(表面张力仪)TRACKER
法国泰克利斯(TECLIS)泡沫分析仪FOAMSCAN
微观可视化驱油工作站
德国劳达LAUDA Scientific光学粘滞力测量仪LSA100DARF
德国劳达LAUDA Scientific粉末接触角测量仪LSA100POM
在线接触角测量仪
双视接触角测量仪
手持便携式接触角测量仪
LSA MOB-X俯视法接触角测量仪
德国BOROSA高温高压悬滴法张力测量系统L 800
德国BOROSA常压声悬浮系统L200
德国BOROSA L800 高温高压声悬浮系统
