方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The polymeric thin film was prepared on the surface of AZ31 magnesium alloy by polymer plating of 6- dihexylamino-1,3,5-triazine-2,4-dithiol monosodium (DHN) in order to modify its surface feature and to improve its anti-corrosive property. Cyclic voltammetry was used to study the electrochemical reaction and film growth process of poly(6-dihexylamino-1,3,5-triazine-2,4-dithiol) (PDH) film, and the reaction peaks for film formation and growth were affirmed. The polymeric film weight was determined by electronic balance and its insoluble fraction in tetrahydrofuran was also measured. Contact angle meter was applied to test the surfacewettability with distilledwater drops at ambient temperature. Itwas found that the polymer-plated AZ31 alloy showed hydrophobic property with its distilled water contact angle up to 117.2◦. The performance property of polymeric thin film formed on AZ31 surfacewas studied by potentiodynamic polarization and electrochemical impedance spectroscopy (EIS) in the corrosion solution of 3.5% NaCl. The electrochemical experiment results showedthat polymer-platedthinfilmwithhydrophobic and insulative characteristics could provide surface modification and an effective anti-corrosive protection to magnesium alloy substrate compared to the blank one.
改进的Washburn法研究矿物岩石颗粒的表面润湿性
接触角测量仪---如何方便地测量墨水、油墨、涂料等的接触角和表面张力
FOAMSCAN泡沫分析仪表征外部设备产生的泡沫特性
法国泰克利斯(TECLIS)高温泡沫分析仪(泡沫扫描仪) FOAMSCAN HTMP
泰克利斯(TECLIS)界面流变仪(界面张力仪) TRACKER HTHP
泰克利斯(TECLIS)高温高压界面流变仪(表面张力仪) TRACKER H
法国泰克利斯(TECLIS)界面流变仪(表面张力仪)TRACKER
法国泰克利斯(TECLIS)泡沫分析仪FOAMSCAN
微观可视化驱油工作站
德国劳达LAUDA Scientific光学粘滞力测量仪LSA100DARF
德国劳达LAUDA Scientific粉末接触角测量仪LSA100POM
在线接触角测量仪
双视接触角测量仪
手持便携式接触角测量仪
LSA MOB-X俯视法接触角测量仪
德国BOROSA高温高压悬滴法张力测量系统L 800
德国BOROSA常压声悬浮系统L200
德国BOROSA L800 高温高压声悬浮系统
