方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
A molecular clustering physical model is proposed to describe the state of steam molecules in bulk steam phase before condensing on the cooled surface. Based on the general feature of nucleation processes, it is presumed that the steam molecules become clusters with the Lognormal size distribution in bulk steam phase firstly before condensing onto the cooled surface. In order to prove this physical model, the condensation of moist air on the surfaces with different wettability is observed using a high speed camera and microscope. The size distribution of the pre-coalescing droplets with radius of several microns is obtained, and for the primary droplets, about 3–10 nm, the size distribution is generated based on the experimental images reported in literature. It is concluded that the size distribution of the droplets from initial to the pre-coalescing size both satisfy the Lognormal distribution function, this proves the present physical model to be reasonable and consistence with the cluster physical theory. In addition, the observation that the initial condensation mode of moist air on the surfaces (either hydrophobic or hydrophilic) is always dropwise confirms the physical model further.
改进的Washburn法研究矿物岩石颗粒的表面润湿性
接触角测量仪---如何方便地测量墨水、油墨、涂料等的接触角和表面张力
FOAMSCAN泡沫分析仪表征外部设备产生的泡沫特性
法国泰克利斯(TECLIS)高温泡沫分析仪(泡沫扫描仪) FOAMSCAN HTMP
泰克利斯(TECLIS)界面流变仪(界面张力仪) TRACKER HTHP
泰克利斯(TECLIS)高温高压界面流变仪(表面张力仪) TRACKER H
法国泰克利斯(TECLIS)界面流变仪(表面张力仪)TRACKER
法国泰克利斯(TECLIS)泡沫分析仪FOAMSCAN
微观可视化驱油工作站
德国劳达LAUDA Scientific光学粘滞力测量仪LSA100DARF
德国劳达LAUDA Scientific粉末接触角测量仪LSA100POM
在线接触角测量仪
双视接触角测量仪
手持便携式接触角测量仪
LSA MOB-X俯视法接触角测量仪
德国BOROSA高温高压悬滴法张力测量系统L 800
德国BOROSA常压声悬浮系统L200
德国BOROSA L800 高温高压声悬浮系统
