方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Chitosan nitrate (CTS-HNO3) as an electrorheological (ER) material was synthesized by a simple method. The nontoxic and facile chitosan (CTS) as a substrate of the materials, as well as nitric acid were chosen as starting materials. The ER properties of the suspensions of the CTS and CTS-HNO3 materials were researched. The CTS-HNO3 suspension has much better ER performance than the CTS suspension. The ER effect (relative shear stress, τr = τE/τ0) of the CTS-HNO3 suspension (25 wt%) in silicon oil under a dc electric field reached 94 at a shear rate of 14.5 s−1,which is eight times higher than that of the CTS suspension, where τE and τ0 are the shear stresses at the electric field strengths of 4.2 and 0.0 kV/mm, respectively. The formation of chitosan nitrate helped to decrease effectively the shear stress at zero electric field, and to enhance the ER effect of chitosan material markedly. The influence of the surface energy, conductivity, dielectric constant and dielectric loss tangent on the ER property of the particle materials was investigated, and the results indicate that surface energy played a predominant role. Moreover, the magnitude of the ER effect of the CTS-HNO3 suspension was closely related to the shear rate. In addition, the chitosan nitrate had better thermal stability. The properties of CTS-HNO3 are advantageous in its application as an ER material.
改进的Washburn法研究矿物岩石颗粒的表面润湿性
接触角测量仪---如何方便地测量墨水、油墨、涂料等的接触角和表面张力
FOAMSCAN泡沫分析仪表征外部设备产生的泡沫特性
法国泰克利斯(TECLIS)高温泡沫分析仪(泡沫扫描仪) FOAMSCAN HTMP
泰克利斯(TECLIS)界面流变仪(界面张力仪) TRACKER HTHP
泰克利斯(TECLIS)高温高压界面流变仪(表面张力仪) TRACKER H
法国泰克利斯(TECLIS)界面流变仪(表面张力仪)TRACKER
法国泰克利斯(TECLIS)泡沫分析仪FOAMSCAN
微观可视化驱油工作站
德国劳达LAUDA Scientific光学粘滞力测量仪LSA100DARF
德国劳达LAUDA Scientific粉末接触角测量仪LSA100POM
在线接触角测量仪
双视接触角测量仪
手持便携式接触角测量仪
LSA MOB-X俯视法接触角测量仪
德国BOROSA高温高压悬滴法张力测量系统L 800
德国BOROSA常压声悬浮系统L200
德国BOROSA L800 高温高压声悬浮系统
